Request for help in repairing Technics SU-V90D
35,167
Z551 and Z552 are emitter bias resistors.
Their condition (good or bad) does not affect the assessment and evaluation of the circuit at this point in time.
It is possible that Z552 blew when Q558 and Q560 both shorted.
We are trying to establish correct supply voltages at IC501 and IC502.
We were measuring supply voltages and you encountered fluctuating readings. Has this been resolved?
Even if the voltages are now stable, we have not identified why you were getting unstable readings. It would be instructive to find out what was the cause of this.
What caused it?
What was done to resolve this?
KaMel88
Joined May 11, 2026
59
check post no. 59
https://forum.allaboutcircuits.com/...epairing-technics-su-v90d.210443/post-2037415
What caused it?
I think we're at a standstill for now, apart from identifying a few damaged elements :(
35,167
I don't give up so easily.
The proper diagnostic approach is to test functionality, not to search for damaged elements.
I have steered you in the right direction. You need to stay on track and stay focused.
The first step is to verify supply voltages.
You should see the same stable V+ voltage at the collectors of Q501, Q502, Q553, Q557, Q554, Q559.
Similarly, you should see the same stable V- voltage at the collectors of Q503, Q504, Q555, Q556, Q560.
If that is not the case, then there is something wrong with your testing procedures.
KaMel88
Joined May 11, 2026
59
That's right, it turned out that the cause of the unstable voltages was the lack of a board with outputs :oops:
New measurements :
Q557 - B: -4.2v C: 52v E: 0v
Q559 - B: -5,4v C: -52v E: 0v
Q560 - B: 0v C: -52v E: 0v
Q558 - B: 0v C: 52v E: 0v
TP401, TP402 all pins 0v
IC501 - pin 8 : 7,7v
IC501 - pin 4 : -7,7v
IC502 - pin 8 : 0v
IC502 - pin 4 : 0v
Q504 - E: 0v C: -53v B: -8,4v
Q502 - E: 0v C: 52v B: 8,4v
Q503 - E: -7,7v C: -52v B: -8,3v
Q501 - E: 7,7v C: 52v B: 8,3V
35,167
Thanks for these measurements. We are back on track.
We are going to focus on the LEFT channel.
Measure the voltages at Q551, B C E.
Note that it may be easier to measure these at R553 and R555.
35,167
In terms of creating a shopping list for possible replacements, here is what I would suggest, with minimum quantity in braces (QTY). You can buy more for spares.
(4) IC501, IC502 M5219P, try RC4558P
(2) Q502 2SC2631
(2) Q504 2SA1123
(2) Q551, Q552 2SC1815
(2) Q558 2SC3281
(2) Q560 2SA1302
(2) R560, R564 2.2Ω 2W
(2) R568 0.1Ω 0.25W
(2) Z552 0.22Ω 5W wire-wound
35,167
We don't yet know which components caused the catastrophic failure. Our focus is on getting the LEFT channel working so that we can get some real live voltages. I am contemplating replacing Q551 in the LEFT channel as a first stab at it.
Sooner or later you will need to buy components. Rather than placing multiple orders, it would be better to get them all at once in order to save time and shipping charges.
You will have a hard time replacing Z552. I am suggesting getting two 0.22Ω 5W resistors to replace the one dual resistor.
KaMel88
Joined May 11, 2026
59
Here's a list of the components I need, along with my suggestions. Please confirm compatibility and help me select the remaining components:
1. IC501/IC502--- M5219P
https://www.digikey.com/en/products/detail/texas-instruments/RC4558P/277060
2. Q502------------- 2SC2631Q --?
3. Q504------------- 2SA1123R -- ?
4. Q551/Q552------- 2SC1815BG
https://www.digikey.com/en/products/detail/onsemi/KSC1815YTA/1047381
5. Q558/Q557------- 2SC3281 -- ?
6. Q560/Q559------- 2SA1302 -- ?
7. Q556-------------- 2SA1535AQRS -- ?
8. Q554-------------- 2SC3944AQRS -- ?
9. R560/R564-------- ERD25FJ2R2 2,2 1/4
https://www.digikey.com/en/products/detail/koa-speer-electronics-inc/CF1-4CT52R2R2J/13537675
10. R558/R557-------- ERD25FJ331 330 1/4
https://www.digikey.com/en/products/detail/koa-speer-electronics-inc/CF1-4CT52R331J/13537270
11. Z552-------------- ERF3GBKR22N
https://www.digikey.com/en/products/detail/yageo/SQP500JB-0R22/9167787
current basket :
https://www.digikey.com/short/bh73403z
If anyone has or knows where to find the originals, please let me know.
@abrsvc You wrote at the beginning that you have some components, please let me know how I can contact you because I can't send you a private message.
@MrChips In your proposal you provided higher resistor values, will these be better than the original values? Will my proposal, IC501, be better?
35,167
Q501, Q502 ---- KSP43BU
Q503, Q504 ---- KSA1013YBU
Q553, Q554 ---- TIP29CG
Q555, Q556 ---- TIP30CG
Q557, Q558 ---- 2SC5200
Q559, Q560 ---- 2SA1943
Which resistors are you referring to?
KaMel88
Joined May 11, 2026
59
I was referring to the R560 resistor you mentioned in post #67. You gave a wattage of 2.2Ω 2W, while the original is 2.2Ω 0.25W.
I compared the values of your suggestions with the original parts:
Are you sure they will be sufficient? They differ significantly from the original parameters.
KSP43BU which you provided as a replacement for Q501, Q502 has a different pinout, photo in attachment.
If we manage to get the amplifier working, I would like it to be rebuilt with good quality components
Will these solutions be better?
Q501, Q502 ---- https://www.digikey.com/en/products/detail/onsemi/KSC2383YTA/1048940
Q503, Q504 ---- https://www.digikey.com/en/products/detail/onsemi/KSA1013YTA/1048933
Q553, Q554 ---- https://www.digikey.com/en/products/detail/toshiba-semiconductor-and-storage/TTC004B-Q/6600430
Q555, Q556 ----- https://www.digikey.com/en/products/detail/toshiba-semiconductor-and-storage/TTA004B-Q/6600426
Final basket:
https://www.digikey.com/short/dc5z80hw
KaMel88
Joined May 11, 2026
59
Should I also use a higher value of 330Ω 0.5W for the Q558/Q558 330Ω 1/4W resistor?
@MrChips Will the transistor suggestions I gave in post #73 be any good?
35,167
One is not better than the other. One can dissipate more power than the other.
One, you need to purchase 2000 pieces. The other, you can buy as many as you need.
