U need to perfect SMD removal without burning the PCB.
If you are up to it, then I am game.
I can show you what to do and where to look.
# First get a hot gun.
# 60/40 0.8mm solder
# No clean flux used for SMD work.
# A solder sucker
# Solder braid or wick ( good quality)
# Another iron that could control the temp and interchangeable tips is very handy and helpful ( U will need a fat tip set at 400°C to suck up the solder using the wick)
# If possible get some normal flux too.
# and last a computer mother board. A socket 478 is best to practice.
Next some time off to get dirty.
# A solder sucker
