Replacing/repairing power swicth HP 2510p
Status
Not open for further replies.
R!f@@
Joined Apr 2, 2009
10,010
U need to perfect SMD removal without burning the PCB.
If you are up to it, then I am game.
I can show you what to do and where to look.
# First get a hot gun.
# 60/40 0.8mm solder
# No clean flux used for SMD work.
# A solder sucker
# Solder braid or wick ( good quality)
# Another iron that could control the temp and interchangeable tips is very handy and helpful ( U will need a fat tip set at 400°C to suck up the solder using the wick)
# If possible get some normal flux too.
# and last a computer mother board. A socket 478 is best to practice.
Next some time off to get dirty. :D
t06afre
Joined May 11, 2009
5,934
If you have experienced a large power surge. Like SgtWookie suggested. It may be a good chance that also the power unit is zapped also. Have you checked this out
Eugeneb
Joined Nov 8, 2011
11
Yes I have.
Ive hooked up a new HP charger to the laptop and still no response.
Eugeneb
Joined Nov 8, 2011
11
# A solder sucker
Ok Ill try and get these things...old motherboards wont be a problem, have many of them...;)
Status
