Replacing dual rail 24-0-24 volts with 0-24 volts single rail supply.
ajx619
Joined Jul 30, 2018
Hi All,
Thanks for your kind attention. My audio amplifier board (TDA8954) requires 24-0-24 volts 5-Amp AC input and this one has the D25XB60 bridge rectifier and dual rail supply. I have one 9-Amp 0-24 volts transformer. Is there a way so that I can use this transformer instead of the 24-0-24 transformer. BR.png
38,952
Is that 5A and 9A input or output?
You could possibly use two diodes connected in inverse parallel to give a half-wave rectified plus and minus 24V (actually about ±33Vdc) but the ripple would be much higher so you would have to double the size of the filter capacitors to maintain the same ripple voltage.
