replacing an absolete component of converter
yef smith
Joined Aug 2, 2020
1,481
I need 10 units.
I will take into account this website.
Is there a component alternative I could use instead?
Thanks.
panic mode
Joined Oct 10, 2011
5,250
in general, different products are different. so you need to ask yourself what parameters you need to stay the same.
do you need same footprint, or input voltage range or power or ripple or ....
once you know what you are looking for, you will need to dive into datasheets or let AI do the filtering for you.
yef smith
Joined Aug 2, 2020
1,481
Hello the DB02S4815A got instict completely,I cant order it no where.
I need to convert 48V into 15V .
Is there an alternative I can use?
Thanks.
schmitt trigger
Joined Jul 12, 2010
2,229
With the provided parameters, Digikey lists 24 devices. With a different footprint and/or size.
Mouser may offer additional choices.
It’s best that you do the same search and decide which devices you would prefer. As Bob mentioned above, you may require to perform some sort of adapter.
yef smith
Joined Aug 2, 2020
1,481
28,290
With DC to DC converters there are a lot of variables that matter. The first being the input voltage, followed by the output voltage, current, and polarity. After that come regulation and accuracy. Then there is the allowed temperature range , physical dimensions, and mechanical vibration resistance. Finally there is also cost and availability.
To select a replacement you need to define those variables that your replacement must satisfy. Then you will know how to evaluate the candidates for replacements.
