I have an outdoor camera that uses 8 AA batteries and goes through these quickly with the activity it detects and captures (still & video). I have a surplus 12V/9AH/34W battery from a failed UPS device that is less than 3 yrs old. The camera has an external power jack and its book says I could use a 6V/1.5A power supply in place of the AAs. My questions to you engineers more qualified than I am: 1) Can I build a circuit that would let me use a solar panel to trickle charge this 12V battery during the day while it powers the camera - the circuit would feed the camera's external power supply jack constantly while the panel would charge the battery when it has solar exposure? 2) Rather than designing a circuit, should I consider getting a power supply compatible with the camera's power needs, using an inverter to drive this power supply (assuming it's designed for 110V), and a separate solar charger? 3) Skip all this and invest in Duracell?
Any thoughts, ideas, and input would be appreciated! I am aware that I'll need to find a waterproof container for the battery and solar panel.
Thanks!
Dave
Thanks!
Dave
