I have a broken Sony Bravia TV that has popped this fusible resistor RWT05 (Image from the schematic and the component PDF attached). It seems that it consists essentially of a thermal fuse (250v,2A,142C ) in series with a 6.8 ohm resistor. It is very hard to find a replacement..
My question is: is it possible to replace this with a thermal fuse in series with a normal resistor? If not, any ideas?
Apparently the cause for this blowing can be the relay (RY6000 shown in the schematic and picture attached). The relay can be switched manually but how can you check if its operating normally? This has the model DEC DLS1U 12VDC 0.25W.
Thanks in advance,
Todd
Thanks in advance,
Todd
