replace led light with a relay
rclassic
Joined Mar 3, 2025
47
Don't have any way to test the tach wire.Thanks for the input,I'll get the parts ordered this week.should I just assemble the circuit on a bread board
sghioto
Joined Dec 31, 2017
8,729
I would recommend using a breadboard first as might need additional components on the tach input.
Get at least 2 of the 100nf capacitors a 2N3904 transistor and some extra 5.1K resistors.
navedf
Joined Jul 18, 2012
Hi All I am looking for some help with a project I've been working on. I have a adjustable shift light in my truck I would like to remove the 3v led and replace it with a 12v relay to control another circuit. I assume I need a transistor circuit but I don't have a clue what I need for parts.Any help or if someone could point me in a direction would be appreciated. Thanks Rod
Why don’t you consider optocoupler?
sghioto
Joined Dec 31, 2017
8,729
Almost.
See the revised schematic in post #43. Connections and components have changed on pin1.
The 1K resistor R6 should connect from pin6 to the anode of the LED. You show one side connected to pin5.
Don't use those long jumpers for connecting the grounds.
sghioto
Joined Dec 31, 2017
8,729
I hooked it up to power and the led is on?
Wiring doesn't look correct and that's not the correct circuit.
I don't see the cathode of the LED connected to pin5
Use the circuit in post #43.
All the common ground connections including pin8 connect to the negative of the power supply.
sghioto
Joined Dec 31, 2017
8,729
Not there yet.
The resistor on pin1 to ground should be 5.1K not 1K.
Next, the 1K resistor up top is completely wrong along with the wires from the LED.
The left end of the 1K resistor goes to pin6 not pin5, just need to move it to the left one space and the right end needs to move to the right one space along with the red wire from the LED.
