replace led light with a relay
rclassic
Joined Mar 3, 2025
47
Hi All I am looking for some help with a project I've been working on. I have a adjustable shift light in my truck I would like to remove the 3v led and replace it with a 12v relay to control another circuit. I assume I need a transistor circuit but I don't have a clue what I need for parts.Any help or if someone could point me in a direction would be appreciated. Thanks Rod
sghioto
Joined Dec 31, 2017
8,756
Welcome to the Forum, Rod.
Is there a schematic of how that LED is wired?
Is the plan to use that single relay module seen at the bottom of the case?
rclassic
Joined Mar 3, 2025
47
I dont have a schematic,the best I can do would be a picture of the circuit.originally I was going to use the single 3.5v relay but if I need to build a circuit to drive it. Could I just use one of the other 12v relays on the other board? Thanks for the reply!
sghioto
Joined Dec 31, 2017
8,756
If it's a conventional LED the voltage on one leg should be appx 3 volts higher or lower then the other when the LED is on.
rclassic
Joined Mar 3, 2025
47
Ok the voltage is the same on both legs when it's off 3.31v. When it's on the + side is 3.3v but the negative side is 0v
sghioto
Joined Dec 31, 2017
8,756
I believe the negative side of the LED is a switched ground with can be used as the trigger source for an input on that 4 channel relay board.
Connect the negative side of the LED leg to an input on the relay module and set that input to L with the jumper.
Can probably leave the LED installed.
rclassic
Joined Mar 3, 2025
47
The module is from a 12v automotive shift light. Its triggered by engine rpm and I need it to trigger on a relay instead of turning the led on. I have removed the led already if that makes a difference.
rclassic
Joined Mar 3, 2025
47
I'll try using the neg.side of the led for a trigger to see if that will work,my concern with that is the relay will be in the normally open position most of the time. The optocoupler circuit would be a possibility
