no, but i have one in the house
everything started last year when i was in china and i saw a floor register with motor to open or close
The manufacturer ask me to make a remote control from his cheap thermostat.
When i saw it, i was deceived , and i said i can make a better one.
I took the manual of mine and found the right processor to do the job, found a cheap LCD manufacturer, 1,75 $, found the cheap radio transceiver 2.3$ per piece and start programing
Everything works fine but i got stuck with the battery problem
On mine, i change the battery maybe 1 to 1 and 1/2 year or longer
After a made the first radio control one working , i stopped and decided to make first the thermostat, sell it, then develop the attachment for RF
It is not WiFi, it is just RF. My foal was to make one central unit on the main floor, have one individual thermostat on each room, and when in the room the vents are closed to send data to the main CPU
When all the vents are closed, then i stop the heat or cool.
When first room ask for heat or cool , i start the furnace or AC
In this way i save energy as the furnace or ac will run shorter.
I think i have a movie on you tube i posted for the guy to show the progress, but i have to find the link
One smart guru told me it will not work in a home due to back pressure ????
But is similar when i go in vacation and close all the vents in the some rooms , leaving just one open in the room with thermostat.
I do not know HVAC, but when i return from vacation, the house is still there and i did not see any damages from what ever back pressure .
I will send you the link when i find them
