Removing the adhesive backing on breadboards
Novus_Legio
Joined Oct 5, 2013
14
What is the easiest way to remove the adhesive backing on breadboards?
Would Isopropal Alcohol do the trick? or would it destroy the boards?
Dr.killjoy
Joined Apr 28, 2013
1,196
I would use 91% alcohol and take it easy on it but what is the point of removing the backing ?? Cause it holds the clips in and keeps the clips from grounding out or shorting out ..
atferrari
Joined Jan 6, 2004
5,015
I recall using once, something more like what is good to remove oily substances.
Last time I used some kind of alcohol and a dry clean towel (real cotton) that helped to take away any trace of the sticky thing.
jpanhalt
Joined Jan 18, 2008
11,087
Get a piece of fine steel wire (I use 0.020" or 0.016" stainless). A cheese cutter will work, but the owner of the cheese cutter may not be happy to let you use it. Then slip the wire between the flashing and the breadboard and pull it the full length. That will cut the foam tape. Isopropy alcohol (91% or higher) will probably work to remove the foam tape once the metal cover is removed. I would use VM&P naptha neat or with a little toluene/xylene (5% to 10%) added. DO NOT use a stronger solvent, such as acetone, MEK, lacquer thinner, or pure toluene/zylene. They will harm the plastic of the breadboard.
However, I just leave the foam tape on mine. You may want to reconsider removing it.
John
34,862
Why do you want to remove the metal backing? Attempting to remove it will also pull away the contacts in the breadboard.
takao21203
Joined Apr 28, 2012
3,702
Almost a no-go job- indeed, the spring contacts are attached to the glue pad. I dont know some kinds maybe have them enclosed inside.
Isopropyl isnt nice to plastic, I wouldnt recommend it at all, while lighter fluid doesnt attack most plastic materials.
you can get cans in many small shops.
Also Isopropyl dries out your hands if you use it a lot, not nice either, as well vapours are highly explosive.
Lighter fluid also is flammable but doesnt ignite as easily.
If you handle for instance a bath with Isopropyl, and dont know properly, you can get a larger problem as with lighter fluid, as these vapours creep, while lighter fluid evaporates more slowly.
