None of which has any bearing on REUSING the GPS.What does the GPS have to do with anything? ¿?
Are you trying to stay off grid ??
Phone tracking works with many phone towers and they triangle you location by signal strength and direction compared to the other towers.. You can stay hidden through not so legal ways and its a lot of work to maintain it..... Do not use a GPS jammer.. They will fine you and lock you up ...
Any cellphone? No. Older ones may not have GPS capability (such as iPhones prior to 3G). Newer phones may have the GPS built into a larger IC (combo wifi, cell radio, GPS for instance). A subset of phones will have discreet GPS-on-a-chip ICs such as this one.Is it possible to remove the gps from any cell phone and reuse it ?
why buying them when i can build them? http://hackaday.com/2011/10/01/make-your-own-gps-receiver/ or find them for free
Because you value your time at some price above zero?why buying them when i can build them?
Some of us have more money than manual dexterity.Because you value your time at some price above zero?
