Hello, my name is Bontor. I am trying to measure current using Hall effect sensor ACS758. Its output have DC offset 0.5*Vcc (I use 5Vcc). The resulting signal is AC signal with 2.5V DC bias.
I am trying to convert the AC signal to DC using precision rectifier circuit in here (http://sound.westhost.com/appnotes/an001-f8.gif). The problem is, with DC bias, the output will not rectified. If I am adding capacitor in series with the input, the bias is still exist (only reduced)
Do any of you have suggestion as how can I get DC output (with voltage = Vpeak of the AC signal) from the Hall effect sensor? I am going to read the value using Xbee, which is a radio module that cannot be programmed. Therefore, I am planning to read just the DC value and calculate RMS by dividing it with 1.4 (square root of 2)
