I have a remote control that keeps running flat. It takes a button battery. The battery voltage is 3 volts. I can only use the remote control twice for about 2 hours. I contacted the company and they replaced the remote for me but i have got the same trouble. I am using the best duracell batteries but even these dont last. I checked the voltage of the battery when the remote control does not work and it reads 2.9 volts. This means the voltage as only got to drop 0.1 of a volt for it not to work. Obviously it is a badly designed circuit, theres no point in me changing it again. Do you think i could modify it to take 2 batteries instead so it would have 6 volts but then i would assume it would damage the circuit if its not designed for this. Any other options you can think of. Thanks
