I've been working with a mate, who has been adding more structure to the program, while I've been trouble shooting.
There have been lots of issues, and I wondered if any were caused my me making the PCBs. I'm up to PCB8, and hopefully somewhere near the final design of the board, so I decided to have them made professionally. II received them back yesterday.
Today I propagated the first board, then smoke tested it, 'no smoke'. I connected all of the peripherals in turn and they almost all worked, I think the issues are separate, and to be looked at later.
It was nice to work on the manufactured PCB, as this is my first time. Before when soldering in the PIN connectors, I had to slide the plastic separator to the other end, solder then one the bottom of the board, then solder the top of the board, then slide the plastic back, and this was problematic, and took some time, so lined holes are a luxury.
The incremental encoder compass is on the second PIC, and an SPI SLAVE, but the DATA is still sent via one of the tracks, which hasn't been changed from out of date programs, so this needs doing.
Next I've got to make one for my frined, and carry on developing.
Cheers, C.
Cheers, C.
