Relay with a 10-32+VDC Input
Friz
Joined Oct 28, 2014
14
I have been trying to build a circuit that takes a nominal 12VDC input to energize a relay. The contact side of the relay will need to handle 15+ADC of current. So to attempt this I create a zener diode in parallel with the coil of the relay that is rated for the coil of the relay, 12V. I take a resistor in parallel and size it appropriate so that the relay will turn on correctly when 12VDC is applied. My problem is that when I apply 32VDC the bias resistor is either taking 15W of power or the relay begins to take to much power. I fill like this is an easy circuit and I am just over thinking all of it. Does anyone have any advice?
The goal is to have a relay at 12VDC and to make it withstand 32VDC normal and reverse polarity for up to one hour.
Thanks!
Friz
Joined Oct 28, 2014
14
This is a sample of what I was trying at 32VDC. In this sample the R4(225) is the resistance of the coil. And the part is rated for 30mA so it wouldn't work.
Here is the same circuit at 12VDC and this circuit works fine. I've tried different relay coils and what not, I get the same results.
dl324
Joined Mar 30, 2015
18,339
Try putting the zener diode in series with the resistor.
EDIT: You actually need 2 zeners to drop the voltage 20V so the relay sees 12V. If the zeners can't take the power, you can use add a power transistor.
Friz
Joined Oct 28, 2014
14
EDIT: You actually need 2 zeners to drop the voltage 20V so the relay sees 12V. If the zeners can't take the power, you can use add a power transistor.[/QUOTE
I've done that before, and from what I have found if it is in series in forward bias, it will drop .7VDC and act as a normal diode. This provides to much wattage for the coil of the relay. If it is in reverse bias, it will not break over till the zener voltage is reached and when it does it drops that voltage, so this only works for when I am at 32VDC and not 10 then. Or am I missing something?
mcgyvr
Joined Oct 15, 2009
5,394
You are not missing anything.. But we are.. You are failing to give us information (or didn't make it clear)..
You did NOT state that you need the relay to work across an input range of 10V? to 32V
So please try to restate your problem again..
Like..
"I need to use a 12V relay and it will need to operate with a voltage as low as "X" and as high as "Y"
The circuit should also be protected from reverse polarity.."
Friz
Joined Oct 28, 2014
14
Okay, sorry about that.
I need a 12VDC relay that has to be energized when the circuit has 10VDC-16VDC applied to it. The circuit must be able to withstand both normal and reverse polarity up to 32VDC for one hour without damaging the circuitry, but it does not have to work across the 16-32VDC range. The contact side of the relay must be able to withstand 15-20ADC of current. .
I hope this is easier to understand, thanks!
blocco a spirale
Joined Jun 18, 2008
1,546
Not really.
The relay operates at 10-16VDC, can withstand up to +/- 32VDC, "but it does not have to work across the 16-32VDC range"
So, when 16-32VDC is applied it does nothing?
dl324
Joined Mar 30, 2015
18,339
What is the part number for the relay? We need to know the pick-up and maximum voltages for the coil. Coil resistance is 225 ohms?
Why do you require reverse voltage and over voltage protection?
ian field
Joined Oct 27, 2012
6,536
Thanks!
Its the sort of job I'd chose a solid state relay - the inputs can be typically 5 - 24V.
Someone else posted Zener shunts and current limiting resistors that would work with a regular relay - it would be even easier with a SSR.
AlbertHall
Joined Jun 4, 2014
12,626
This gives 10.5V across the relay at 12V input and 12V across the relay with 32V input. The relay will not operate, but no damage with negative voltages.
Friz
Joined Oct 28, 2014
14
I'm kin
Not really.
It can do nothing or it can work. All it has to do is survive the 32VDC, but it must work at a voltage of 10-16VDC.
dl324
Joined Mar 30, 2015
18,339
I might need to look for different relay
If you do this, get a solid state relay as suggested earlier. It will support a wider voltage range.
If you don't, you need to consider the pick-up voltage if you're going to operate at less than the recommended coil voltage.
Friz
Joined Oct 28, 2014
14
I would use a solid state relay, but the output is using a DC pulse current that can max out at +/-15A. I though solid states are used with AC outputs?
ErnieM
Joined Apr 24, 2011
8,415
You might as well look at one hour as forever, if something gets hot it will be very hot.
Something that would work very well here is a simple low drop out voltage regulator, just select something carefully as you have about 1 watt at max input, and you want to keep the junction cool enough not self destruct.
The KA78L12 will thermally protect itself (finally found the ref in the data sheet) But has a large (1.7V) dropout voltage, meaning the low input end may be a problem.
An NCV8674120 may be a better choice, good dropout, good to +45 and -42 volts in, but it is only available in surface mount.
