Relay TQ2-L-5V Help
Ian0
Joined Aug 7, 2020
13,276
It might even be able to work with a CD4049. What I see is that it would require both sink and sourcing enough current. Realizing that, the CD4049 will not work, it can't source much current running at even 5 volts. So the application will require a TTL IC that can both sink and source.
It would work really well with a dual low-side driver IC. such as TC4426 or TC4427
AnalogKid
Joined Aug 1, 2013
12,268
Use a 74HC inverter. This circuit is self-timed, so that the coil doesn't remain powered if the processor stops.
Really like this approach, because the relay coil current is not going through the timing capacitor.
AC series CMOS can sink and source 24 mA per output, which is significantly better than TTL. 3 inverters in parallel make a serious driver.
ak
ps. "sanitary" - ? ? ?
sghioto
Joined Dec 31, 2017
8,751
Don't ask me ask MisterBill2.
However I don't even want to look at an IC much less touch one if it's not sanitary.
