I'm need a motor control circuit that has these features:
*3 inputs, forward, backward, stop. All inputs are one-shot 12v pulses.
*With a pulse on either dir input, the motor must keep running until the stop signal is pulsed.
I was thinking to do this with relays. It will be a battery powered application, and so I like that the relays have absolutely no standby current.
Was hoping someone could take a quick look at my schematic and maybe point out to me if this will work? I don't have three DPDT relays at hand to prototype right now... My inputs are actually 5v digital pins, which will switch a transistor which will switch a relay. But I was thinking to deal with this later.
The three relays are color coded and marked, so I hope you can see which coil belongs to what switches etc.
