Hey
I want to draw footprint for relay: http://www.farnell.com/datasheets/1558263.pdf?_ga=1.208330964.770389778.1476119739.
The problem is that i do no understand what are the dimensions of that relay. On page 2 the datasheet says that the
length of relay is 1.15 +- .02 / 29.2 +- .5. Which units are used to specify the dimensions and how to convert them to mils or mm?
Thank you for your answer.
