Relay BU-5084M polarity ?
Status
Not open for further replies.
DrizzleMan
Joined Nov 13, 2013
3
I have a question about relay polarity.
I purchased 4 BEULER BU-5084M relays that has a Negative Spike Suppression protection.
My question is: Does polarity matter?
Should pin 85 be grounded and pin 86 +12v ??
I tried looking for the BEULER website could not find one.
Thanks in advance for your help.
30,699
If this is a reverse EMF diode across the coil, then it need to be connected with the correct polarity.
Going by the numbers, this is an automotive relay?
You can confirm polarity if you have a meter that has diode testing capability.
DrizzleMan
Joined Nov 13, 2013
3
Follow-up Findings:
I got a hold of the Vendor Tech support.
Relay BU-5084M has no diode and polarity does not matter for this specific relay.
Bench tested to confirm.
Thanks for the help.
bertus
Joined Apr 5, 2008
22,944
I aleady closed an other thread about the same subject.
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
There will be enough sites where automotive questions can be discussed :
Member selected automotive forums
There is no need to hide the automotive needs.
Our members will discover and report this.
If you try it a third time a ban will follow.
Status
