Regulated Box Mod Mathematics
starrvenom
Joined Apr 12, 2016
2
Hi Everyone! I'm pretty new to the forums here but after taking a look around I thought this was the best place to seek an answer to a question that has been irritating me to no end. I'm a vaper (holla to the others who might be in here), and a pretty advanced one at that. I am however just now beginning to desire a deeper understanding of the mechanics of these devices that i use every day, so that, hopefully, one day soon i can build them. So i have a series box mod that is regulated (power mode in W). My question is why does my mod only fire, if regulated at a certain wattage, down to a certain percentage, say 70%, of my remaining battery power? I have a vague understanding of why, but I'd really like to have a concrete answer, and to see the math behind it, and I haven't been able to find that anywhere else on the web.
If anyone here is kind enough to show the math for this problem, the details of the particular circuit i have set up would be a series of two batteries with capacities of 3000 mAh and a max of 35A discharge connected to a parallel set of .36 ohm resistors, and I have the wattage set to 120, which by the way is well within the parameters of the device that they are housed in.
ronv
Joined Nov 12, 2008
3,770
To answer your question we will need to know the battery voltage and the circuit that provides constant power/current. But I would suspect that the battery voltage falls below the point that the circuit can provide the 25.8 amps into .18 ohms.
starrvenom
Joined Apr 12, 2016
2
The Voltage of the batteries is 3.7, as for the voltage output falling once they reach a certain level of charge, that much i assumed, i was just wondering if there might be a formula or a general mathematical principle to determine at what level of charge the circuit would fail.
ronv
Joined Nov 12, 2008
3,770
What is inside this box?
OBW0549
Joined Mar 2, 2015
3,566
It depends entirely on the characteristics of the particular voltage regulator chip used.
21,228
There are two relationships at work:
  1. Ohm's Law, which establishes the relationship between voltage, current, and resistance. Voltage(E in volts) = Current (I in Amperes) × Resistance (R in Ohms)
  2. Power equation which relates power to voltage and current. Power(P in Watts) = Voltage(E in Volts) × Current(I in Amperes)
Starting with a fresh battery of 3.7 Volts and a load of 0.18 Ohms, I would expect that the current in the load would be:
\(\frac{3.7\; \text Volts \math}{0.18\; \text Ohms \math} \approx 20.55\; \text Amperes\)
The power consumed by the setup would be about 76 Watts. As the battery discharges the voltage starts to drop slowly at first and then quit rapidly. When the voltage is at 3.2 Volts for example the current will drop to about 17.75 Amperes and the power will also drop to about 56.89 Watts and it contiues from there until the battery can no longer supply any current at any voltage.
BTW -- what is a series box mod?
ronv
Joined Nov 12, 2008
3,770
