Regarding the components value
Raj Waghmare
Joined May 8, 2019
32
I have a reference design where the mppt management has been used. The input is 12V DC. In this reference, it is used to charge 7.4V Li Ion battery. I want it for Li Ion 3S4P 12V Li Ion battery. Please tell me what should be the values to get 12V output. Kindly find the picture
Delta Prime
Joined Nov 15, 2019
1,311
Are you flexible must you use the CN3722 IC.Also 3S4P 12V Li Ion battery, is this a battery pack. And I must know your power supply specifications you intend to use. For the charging circuit .
Delta Prime
Joined Nov 15, 2019
1,311
Can you use two 12 volt solar panels
I need more information you got to help me out. Is this proprietary for specific application a specific device.
Charging lithium ion batteries can be very dangerous they will explode I need all the information you can give me.
Raj Waghmare
Joined May 8, 2019
32
I have attached a project document. Please go through that.
