reducing volume in my flight helmet
skydver
Joined Mar 3, 2018
3
I am sure there is a simple way to do this but not for me. My electronics knowledge is minimal. I learned just enough to get my Airframe/Powerplant mechanic license. I Fly helicopters and when I do I am required to wear a flight helmet. I have turned the radio and the intercom volumes all the way down and yet it still is way too loud. I would like to build an adapter to mute the volume by 50 - 75%. I can then turn the volume up to a bearable level. My helmet has 2, 300 ohm speakers, L&R but not stereo. What do I need to do to accomplish this ? I can not modify my helmet so I need something I can plug into the headset jack and then plug my helmet into.
Any help would be greatly appreciated
dl324
Joined Mar 30, 2015
18,392
If the speakers are connected in parallel, you could do something like this:
Clockwise rotation increases volume.
You need to consider maximum power that can be delivered to the speakers. A pot connected as a rheostat could be burned out if you set the resistance too low. You could insert a resistor in series to limit the maximum dissipation in the pot.
300 ohms would let you reduce volume by 50%. I'd suggest that you select resistor values based on the lowest volume you can currently set.
skydver
Joined Mar 3, 2018
3
So if I put a 300 ohm resistor in series with each speaker would that cut the volume by half ? Do I need a variable resistor or can I use a fixed resistor ?
dl324
Joined Mar 30, 2015
18,392
Yes. If the speakers are connected in parallel, you'd only need one resistor connected before where the speakers are connected.
