Reduce 24V to 12V for my Capacitive sensor with optocoupler module
Sciuruz
Joined Oct 28, 2018
Hi
I have a little prodject going on with my 3D printer CR-X from creality.
I want to put an auto bed leveling on it, but my circuit bord only supports 12V and the power supply is 24V
I tryed using the Voltage devider with 2 simmular resistances but my Capacitive Proximity Sensor uses about 200mA so the voltage drop is to much.
So my question is is there some way to modify the board that I'm using? Change the resistors? I could always use a 12V power suply from the outlet or an power drowngrader, but I want it to be a complet kitt whitouth the extra parts.
The board
https://www.ebay.com/itm/12V-1-Chan...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
https://www.thingiverse.com/thing:2906283/comments
The Sensor
https://www.ebay.com/itm/DC6-36V-3-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
The printer
https://www.creality3d.cn/creality3d-cr-x-p00252p1.html
The components on the board
R1= Brown, Black, Red, Gold = 1Kohm+-5%
R2=Brown, Black, Orange, Gold =10Kohm +-5%
Led: Probably a normal 5V led or something?
Optocoupler
http://www.everlight.com/file/ProductFile/EL817.pdf
Also se picture
Please correct me if I'm wrogn when you look at the pictures of the resistances and let me know if you need more information
bertus
Joined Apr 5, 2008
23,000
Why does it say that the sensor can be powered with 6 - 36 Volts?
Just power the sensor with the 24 Volts from the printer.
Replace the 1K resistor R1 with a 2K2 resistor on the board.
The output of the sensor goes to the input of the board and the other side of the input of the board can go to the 24 Volts.
The output side can stay as drawn.
Bertus
Sciuruz
Joined Oct 28, 2018
Hi Bertus
Thank you for answering.
The sensor supports voltage ut to 36 volts, but It's the card I'm Woried about. So if I got al the info right it should work like the athatchment in this post? I'm kinda new to resistance and how everything works.
ebp
Joined Feb 8, 2018
2,332
The sensor appears to have an open collector output. You don't need an optocoupler at all. You can directly drive an input that operates at any logic voltage by using a pullup resistor (e.g. about 5k for 5 volt circuits should be OK, connect between the 5 V supply for the board and the input), connecting the "common" wire from the sensor to the "common" (ground) for the logic circuit and the negative of the supply for the sensor, and the positive for the sensor to whatever supply is being used.
I strongly recommend you test this first with a meter before making the connection to the logic circuit (microcontroller), just in case the description for the sensor is incorrect. If you measure the voltage between the sensor output and the sensor negative with the sensor's supply connected and nothing else, you should see no change (maybe a few millivolts) in the voltage at the output of the sensor if it really is open collector.
There MAY be some reason that is not apparent why you would want to use the optocoupler, such as some unusual connection between the power supply that would be used for the sensor and the logic circuit.
Rares23
Joined Jan 26, 2021
Sorry. I'll try it out and see how it works, I should have a som lying around here. Thanks all your help.
Hello ! have the same problem. How doees it work ? is 24V power supply working with 12V optocoupler with the 2.2kohm resistor ? Diagram from bertus is correctly set up ? Thanks !
