Rectifier optimization in ADS
wajid ali Khan
Joined Jan 10, 2019
5
Hi, I want to optimize the efficiency of a rectifier for a rectenna,
1-How can the rectifier efficiency (efficiency=(P_Probe2.p[0]/dbmtow(pin))*100) be set as an optimization goal?
2-While optimizing the matching network parameters, what limits (min and max) can be set for the electrical length E of the transmission lines and stubs for optimization?
Papabravo
Joined Feb 24, 2006
22,113
You posted in the subforum for "RF and Wireless Design". Member @sagor is suggesting that you post in the "Homework Help" subforum. I should note that it is not the "Homework Done For You" subforum. Just reposting won't help much because the way "Homework Help" works is that you have to show your best effort at solving the problem.
It also might help if we had a diagram of what you have because your words do not convey an accurate picture. That is not your fault, because there are no words that would accurately convey what you are trying to do. Have another go at it and ask the moderators to move this thread if it is appropriate.
wajid ali Khan
Joined Jan 10, 2019
5
You posted in the subforum for "RF and Wireless Design". Member @sagor is suggesting that you post in the "Homework Help" subforum. I should note that it is not the "Homework Done Fou You" subforum. Just reposting won't help much because the way "Homework Help" works is that you have to show your best effort at solving the problem.
ok thanks a lot...
