Rectifier for 220 AC to DC to supply solenoid valve
Gurumurthi
Joined May 3, 2019
I have a solenoid valve in a Crane’s hydraulic system to be tested. Specs of solenoid valve mentioned as 220V, 60 Hz.
Solenoid valve didn’t energise when 220, 50 Hz AC supply given.
Understood from maker that a rectifier is incorporated in the Din connector and final supply to the Solenoid coil required is “DC”.
Rectifier not available to test the valve. The resistance of solenoid coil mentioned as “150 ohms”, measured & found correct.
Tried with Bridge rectifier, blowing out repeatedly.
Can any one help me with solution reg correct specs for the rectifier to be used.
Gurumurthi
Joined May 3, 2019
A correction(typho error) -solenoid coil resistance is 1500 ohms.(not 150 ohms).
38,948
With 1500 ohms the current with 220V full-wave rectified voltage should be less that 0.2A RMS.
What was the voltage and current rating of the bridge you used?
It should be a least 400V and 0.5A.
Gurumurthi
Joined May 3, 2019
Many thanks Mr.Crutschow,
The rectifier used was 700 v ac(RMS) and 2.0 Amps, but there was some short circuit in the wiring, now eliminated and working fine.
