Rectifier filter
Kaiser Ed Bayawa
Joined Mar 19, 2015
64
I am having a problem with my power suppy. The 12v transformer, I used bridge rectifier and a capacitor 2200uF filter.
But still the output is not smooth.
Do you have any idea about this filter?
ronv
Joined Nov 12, 2008
3,770
It should work, but the ripple will depend on how much current you draw from the supply.
MrAl
Joined Jun 17, 2014
13,704
Add more caps in parallel, that makes it smoother.
To get very smooth you need a voltage regulator.
18,104
You've gotten two solutions, more capacitance or a voltage regulator. There may be other solutions if you give more details about the rating of the transformer and the load you need to power.
12,131
With the schematic you posted, the output never will be "smooth". Ever. It always will have some ripple. Increasing the size of the capacitor will decrease the ripple amplitude, but it will not - cannot - eliminate it.
ErnieM
Joined Apr 24, 2011
8,415
Define smooth = how much peak to peak ripple can you allow?
If that is zero you need a voltage regulator. If some number tell us what The lad R is and we can show you how to calculate how much capacitance you need.
alfacliff
Joined Dec 13, 2013
2,458
your circuit is of a simple "brute force " filter. more capacitance is need for this type. even with a regulator, more filter cap would be needed to prevent the regulator fromj dropping out under load.
ErnieM
Joined Apr 24, 2011
8,415
For a 2200uF cap, 60 cycle full Wave bridge with the full load of 0.75ma one should expect on the order of 2.8 volts peak to peak of ripple.
Doubling your cap halves that number. Ten times the cap drives it down to just 0.28 V p-p.
(edited to add spec'd load current)
18,104
Those depend on the load. No load, (almost) no ripple. Loading at double the rating, big ripple, and the cap does little except increase the total load.
