Receiver Sensitivity Calculation
Cerkit
Joined Jan 4, 2009
287
I have a receiver with an impedance of 50Ohms. I have calculated the minimum receiver sensitivity to be -10dB.
Is there a way I can express the sensitivity in Volts? Can I convert the dB to power then calculate V = P/(R^2)
Cerkit
Joined Jan 4, 2009
287
Please help me understand. I have a transmitter of 10watts (40dB) and I need to know what the minimum sensitivity of my receiver needs to be if I have losses of 20dB and need to allow for an additional margin of 30dB. Which is why I got -10dB.
So was trying to convert the sensitivity to a voltage value.
But I still need to get my head round a few things clearly.
bertus
Joined Apr 5, 2008
23,029
Decibels are a ratio between powers or voltages.
There must be a reference to calculate the power or voltage.
Read the PDF I gave you.
The power of your transmitter is quite high with the mentioned 10 Watts.
It is quite normal for a communication receiver to have a sensitivity of the 0.3 μV, I mentioned.
Bertus
John_2016
Joined Nov 23, 2016
55
10W are not 40dB, but 40dBmW often the W of dBmW is omitted when for instance working with microwave circuits if all values are small.
Not to be confused with dBmV
John BG
John_2016
Joined Nov 23, 2016
55
it would greatly assist the readers of your question to have the question supported with more details like:
1.- transmitter specs: model, circuit, block diagram, a photo
2.- same for the receiver:
