really need help on electronics coursework really really stuck!!!!
khaasus
Joined Feb 5, 2012
3
hello their i am really really stuck on my coursework and it has to be in for thursday 9th feb please help.
okay so basicly were using a program called icon 2 soft electronics, and were supposed to make a program that hits the mark breif. my task is to incorporate various latches and stuff to make my program and i am very stuck.
The target is for me to:
1 incorporate digital switch/es and analogue sensor/s
2 use switches/sensors which perform both AND and OR functions on a single rung
3 use a software switch as a latch
4 use a software switch which is triggered from a real or virtual output on another rung
5 use a combination of software switches to control an action on a single rung
6 use a counter which is reset either automatically or manualy
7 used two types of timer funcions in one program
9 use pulse production with justification of the frequency setting chosen
10 use a sequencer function
my project tittle is a movie projector and is based on that. My specification for this is :
when switch one is pressed indicator one turns on and the projector starts up
when switch one is pressed again indicator 2 is turned on after a period of 4 seconds and the projection begins
when switch 2 is pressed indicator 1 flashes for a period of 2 seconds and then stays on and the projection is turned off
when switch 3 is pressed indicator 1 and 2 flash for 2 seconds and the whole projector turns off.
i need to incorporate that into rungs and place it into the software and hit the targets above i really really need help on this as i am really stuck and have a feeling am going to fail as no one not even the teacher or my friends are helping me please can someone help me or inbox me to help me i will give them the program if needed its free and il give them a my email address
really appreciate your help.
R!f@@
Joined Apr 2, 2009
10,014
Sorry Mate...
We do not work that way..here no one will spoon feed you.
If you want help, you have to come up with something.
Just throwing in the question will get ur thread ignored.
So draw something ..anything......u need to start, it's your life, deal with it like man.
Start thinking.
Georacer
Joined Nov 25, 2009
5,182
In case Rifaa wasn't understood, we need you to post any progress or effort you have done so far, before giving you any help.
We will not do your homework for you.
khaasus
Joined Feb 5, 2012
3
yes i understand thanks and yeah i am still working on it and will be posting and image of the rungs soon =D
khaasus
Joined Feb 5, 2012
3
so far this is what i got i just wana try making the actualy specification before i try and hit the target so so far when i press switch 1 indicator 2 turns on and stays constant i cannot get it to do that once i press it again releasing the acutal switch 1. in rung 3 i can get the indicator to blink but not stay constant after the 2 seconds instead i get a 2 second hold and then a blink that never ends i am still working on it please could use ur help thanks
