One path was through a 470Ω ½W resistor which showed zero signs of heat stress and had the same value.
The other path(s) were the rabbit hole, where the trace beneath the darkest resistor was browned (replaced with adhesive copper tape to be sure), the network of BJT transistors, 4 Zener Diodes (More and More the target of my inquiry, but I'm unsure of the values of 3 of them.) A LOT of standard 1A diodes that test fine/no reverse leakage. Then add in two taps for power from the air-controlled signal input.
So, total is:
Inputs:
5 Potentiometers (2 controlled by foot/air pressure)
1 Single Stitch button (Double Pole, Triple Throw) That charges the cap and activates the motor at speed determined by 2 pots (1 user adjustable) for one stitch.
1 Reed Switch indicating Needle up
1 Output: Universal Motor that drives entire sewing machine gear train via 2 belts.
The SCR immediately next to the burnt resistors had failed open, along with the downstream motor control SCR.
I'm unsure What else happened at time of failure, as another tech had worked on the board before I got it. If I didn't have the photos from the last time this happened, I'd be completely guessing the values and components. This behavior is not much different from what I'm doing now, but I digress...
First picture is the board it connects to, and the air-diaphragm resistors/switch.
Second picture is component side, the spade connectors, from edge of board are: reedA reedB motorA motorB Light A Light B. The burnt resistors were around Th2, in the lower left-middle of the component side of the board, where you can see the CR-100 Sharpied in, along with initial guesses as to resistor values.
Third picture is reverse side of board, if you flip it vertically, and scale just a touch, you can trace the connections after a bit of spatial visualization. I sharpied in some diodes and caps to help align, but ended up aligning on pushbutton notch in board and notch in center where the air diaphragm goes through to visualize.
Last image is board soldered into housing and connected to motor, switch, light, etc.
Click Images for VERY FULL SIZE versions:
Housing and air control (cylinder in middle), power switches, power input:
Component side and top traces:
Copper side traces:
Assembled and in place to test with housing and board together:
So, total is:
Inputs:
Copper side traces:
