Clarity reading this capacitor please
B-JoJo-S
Joined Jan 3, 2026
600
471 @6.3V electrolytic cap.
I know it's 47 somethings. 47µF? 47nF? pF?
470 somethings? I'm not accustomed to these sorts of caps.
470µF (probably but unsure)
dl324
Joined Mar 30, 2015
18,496
Surface mount electrolytic caps use two conventions. Either uF (with no uF) with voltage (e.g. 4.7 6.3V for 4.7uF) or a value in pF (e.g. 471 6.3V for 470pF).
B-JoJo-S
Joined Jan 3, 2026
600
This is where the confusion comes in. I'm guessing it's 470µF. At 6.3V that's HUGE for a 470pF cap. And I don't think I've ever seen a Pico Farad cap being electrolytic. Hence, the reason for asking. If I scavenge these I'd like to know I can use them knowing what their value is.
B-JoJo-S
Joined Jan 3, 2026
600
Oh, and those caps are through hole; not surface mounted.
I know that a 473 cap (tiny little thing) is a 47nF cap. Or 47,000pF. I DO know how to read those. Just unsure of this case. I've never seen this before.
ericgibbs
Joined Jan 29, 2010
21,637
Hi B.
470uF 6.3V polarised cap
E
  • This is a surface-mount solid aluminum electrolytic capacitor, commonly used on motherboards.
  • It is rated for 6.3 volts.
  • The markings indicate a capacitance of 470 microfarads (
    ), as "471" translates to 47 followed by 1 zero.
  • The red stripe on the top indicates the positive polarity side of the capacitor.
Futurist
Joined Apr 8, 2025
950
Capacitor markings are truly a mystery to me sometimes, I'd say its 470uF.
I kid you not, AI just gave me this BS, how are companies daring to describe this as "intelligence"...
An electrolytic capacitor marked "471" 6.3V is an 470 μF capacitor with a rated working voltage of 6.3V. The "471" follows standard component codes: the first two digits (47) are the base value, and the multiplier (1) adds one zero, giving 470 in picofarads, which equates to 470 μF. [1, 2, 3, 4]
B-JoJo-S
Joined Jan 3, 2026
600
I wouldn't have thought this the positive indicator. Usually electrolytic's similar in nature have either a black or white marking. If you look at the silkscreening the red painted side correlates with the white silkscreening on the PCB.
And just for clarity, these caps ARE through hole.
WBahn
Joined Mar 31, 2012
33,325
Pretty much any marking that calls attention to one lead of a device is likely a polarity marking. But whether it is calling attention to the positive or the negative lead can be a matter of debate.
