Reactance of pulsed DC
eromlignod1
Joined Sep 26, 2017
58
Reactance depends on inductance. As I mentioned, this is a store-bought, radial-lead inductor. The inductance is in the spec sheet.
Don
MaxHeadRoom
Joined Jul 18, 2013
30,791
Reactance, is a form of opposition that electronic components exhibit to the passage of alternating current because of capacitance or inductance. In some respects, reactance is like an AC counterpart of DC (direct current) resistance.
MaxHeadRoom
Joined Jul 18, 2013
30,791
Thanks, Max. Actually, I was replying to the other poster who was saying that a saturated coil has neither inductance nor reactance, which is nonsense.
Don
Inductive reactance only occurs when AC is applied.
The opposition to current flow through an Inductor when AC is applied is called Inductive Reactance and which depends lineally on the supply AC frequency
eromlignod1
Joined Sep 26, 2017
58
The current one is a Coilcraft RFC1010B-105KE. It's 10 mH and works for most frequencies, but requires a buck converter to limit the applied voltage. I'd like to eliminate the converter and use a coil that will run at Isat with the full 5V supply. Every coil is dedicated to a frequency and there are almost 100 of them. Space is critical and I'd like to stick with the form factor of the RFC1010 series.
Don
eromlignod1
Joined Sep 26, 2017
58
My original question was what is the formula for inductive reactance for a square, DC wave. Several posters tried to tell me there is no reactance, but my measurements from previous experiments indicate that there is.
Don
Audioguru again
Joined Oct 21, 2019
6,826
If you capacitor-couple the DC pulses to the inductor then it gets AC and the peak current is half what it is with your DC pulses but the peak-to-peak signal level is the same.
Why are you overloading the inductor by saturating it? Use a larger inductor that does not saturate at the current you are using.
eromlignod1
Joined Sep 26, 2017
58
I'm using the inductor as an electromagnet. I want the maximum pull I can get from this small form factor. Driving it AC with a cap would double the pull frequency (it pulls with both polarities).
If I had a valid formula for X, I could go through the inductor catalog page and easily calculate what inductor I need to get Isat at 5V for each frequency I want to drive.
Don
ag-123
Joined Apr 28, 2017
294
I think one way is to run it as like a buck converter
https://www.allaboutcircuits.com/te...ysis-of-four-dc-dc-converters-in-equilibrium/
at some frequencies and duty cycle there would pretty much be a 'constant' current across it.
the amount of heat generated may not be small,, it depends on I^2 R, and you can vary I by varying the duty cycle in the case of a buck converter.
Accordingly, reactance do not produce heat? (is that correct)?
https://www.allaboutcircuits.com/te...ent/chpt-11/true-reactive-and-apparent-power/
for heat, it is still the resistance within the inductor that produces it
if you have a superconducting coil, perhaps it can keep the magnet *on* perpetually without power dissipation.
Audioguru again
Joined Oct 21, 2019
6,826
When an inductor is saturated then its reactance is low and its resistance causes heating.
An inductor is usually used for its reactance with AC. An electromagnet can use DC but some use low frequency AC.
