RCA MicroWave RMW953- Solved
MaxHeadRoom
Joined Jul 18, 2013
30,887
#1 Son brought over his RCA microwave, symptom: Dead.
Fuse found blown, replaced and worked OK for several operations, found after a couple more blown fuses that it occurred intermittently when heating cycle had finished and then the door was opened, a study of the schematic and the 3 door switches activated when door open/closed found one to be stuck in, this caused a intermittent dead short across the AC in, one switch is supposed to open as another closes, if both closed (fault) result = blown fuse.
Max.
