Hi Folks
I've been running around the internet for quite a bit trying to find the best solution for the system I am building. It is based around DC solenoids powered by 24vdc.
Parameters:
Load - 24vdc solenoid, 40ohm resistance
Relay - 24vdc actuated mechanical 240v AC max 10A max (resistive load)
Source - 24vdc
RCD Snubber to be placed parallel with load
My understanding is i would be best to implement an Resistor Capacitor Diode circuit to:
- reduce contact arcing on relay
- reduce emf
- reduce backward flow of current to other components.
I have investigated snubbing diodes, but my understanding is that they are slow to dissipate the energy so might impact closing time of the solenoid. I need the switching off of the solenoid to be as fast as possible.
Any help with choosing the right components would be much appreciated.
Basic schematic attached.
Many thanks
Parameters:
Source - 24vdc
- reduce emf
Many thanks
