Hi dears, I have just a couple of questions.
1)I am making a little circuit where I am using a presettable synchronous counter with asynchronous load
I know that is possible to load the PE input with an RC to generate a positive going transition, however someone told me to use a Schmit trigger gate to do that, and I am not so disappointed about it.
But, I always known that is possible to use an RC, with a low reasisteance and high capacitance value. For example: 1K and 1uF.
Is the RC really unsafe for this purpose?
2) I have to make a 3 input NAND gate with three NPN. I can work with a 40193 or a 74HC193.
It is better I choose different transistors depending on the IC I am using?
I have BC337 and BC547 in my drawer.. I am thinking to use BC337..
Consider I still don't have strong knowledge about transistors.
What do you suggest about my questions?
Thank you for your time
Simo
Simo
