Thank your for the Info!
In the absolute worst case the input on the analog inputs of the ADC can geto down to -0.014V. I checked the datasheet already before and it says that the analog input voltage must not go below V_ss-0.3V. So I guess the ADC should without any problem be able to handle negative voltages to lets say -0.2V right?
(i was a bit confused as you said it will break as soon as I apply any negative voltage)
