Lowpass Butterworth Filter
pinkyponky
Joined Nov 28, 2019
373
Hi all,
Please can you open the below link and see the video at 2:18 min. How the 'n' value is determined?. Please anyone of you derive it clearly.
pinkyponky
Joined Nov 28, 2019
373
N is the filter order.
Since there are no “non-integer” filter orders, you round UP to the next integer.
I knew that, it is a filter order, I would like consider this like a example and I have to derive filter order for my circuit. So that's why I asked how to derive that.
LvW
Joined Jun 13, 2013
2,035
The formula you have shown (magnitude of H_lp) applies for Butterworth filters only.
The general expression for the magnitude of a Butterworth response is
|H(jw)| = 1/[SQRT(1+Ω to the power of 2n)].
The quantity Ω is the frequency parameter - normalized to the defined cut-off.
So - when the required magnitude is given you can solve for another unknown (in ths case "n").
pinkyponky
Joined Nov 28, 2019
373
Hi LvW,
Here, the problem is I don't know how to solve the 'n' value. I'm asking you to help me how to solve the 'n' value and if explain step by step it's grateful.
Thank you.
LvW
Joined Jun 13, 2013
2,035
Hi LvW,
Thank you.
Applying the antilog function we have an equation:
0.0707=1/SQRT (....).
After squaring both sides it should be not a problem to solve for "n".
