RC discharging and ohms law
Drmario5237
Joined Oct 14, 2018
65
Hello I understand that t=R*C as to get the time constant of how long it takes a capsitor to drain though a resistor with voltage and current lowering exponentially over that period of time but do I still use ohms law (I=V/R) to get the intial current that the capsitor is draining though the resistor where V equals the supply voltage or what the capsitor is charged to the r represents the resistance of the resistor and the I represents the amount of current I'm getting from the capsitor and resistor keeping in mind the voltage is changing on me as the capsitor discharges and the capsitance of the capsitor is the amount of charge stored up that that it is expontially discharging from. Thanks.
MrAl
Joined Jun 17, 2014
13,754
The short answer is yes, if you need that current that is.
The voltage goes down to about 0.36787944 times the initial voltage after 1 time constant.
The voltage then goes down by another 0.36787944 after 2 time constants.
The voltage then goes down by another 0.36787944 after 3 time constants.
Etc., etc.
So for each additional time constant, multiply the previous result by 0.36787944 to get the voltage at the next time constant.
35,003
The answer is yes, Ohm's Law still applies for the resistor.
Note that the voltage across the resistor is used.
Hence if the voltage Vc is across the capacitor then the instantaneous discharge current I = Vc / R.
For a resistor in series between the supply voltage Vs and the capacitor being charged, the instantaneous charging current would be I = (Vs - Vc) / R.
Drmario5237
Joined Oct 14, 2018
65
Etc., etc.
Is the same drop measurement the same for current (0.36787944) and how did you arrive at that number?
shteii01
Joined Feb 19, 2010
4,644
You can use Ohm's Law for the value at that specific instant.
"RC time constant. It is the time required to charge the capacitor, through the resistor, from an initial charge voltage of zero to approximately 63.2% of the value of an applied DC voltage, or to discharge the capacitor through the same resistor to approximately 36.8% of its initial charge voltage."
https://en.wikipedia.org/wiki/RC_time_constant
36.8% is 0.368 which is what 0.36787944 is when you round it up to 3 decimal places.
AnalogKid
Joined Aug 1, 2013
12,227
Yes. At any instant in time, the current through the resistor is equal to the instantaneous voltage divided by the resistance. As the capacitor continues to discharge, the voltage is decreasing continuously. But instant to instant, Ohm's law applies.
ak
