proper charging and discharging of dc-dc using mosfet
yef smith
Joined Aug 2, 2020
1,481
Hello,tc1261lcs8 needs to be both turn on and off using esp8266 3.3V GPIO pulse and the output needs to charged and discharged with this GPIO pulse.When my GPIO =0V output off when GPIO=3.3V output is ON.
Which is the opposote of what the SHDN does as shown in the data sheet below.I have made an inverter as shown below .
I want to discharge the negative voltage to ground using NMOS.
Vg=5V and Vs=-2V so the NMOS is open.
Howeverthe output only goes from 0 to -1 instead of 0 to -2.4 expected by the formula below as it was withoud the SHDN switching.
Why its not charging back to -2.4V?
another problem is that i want the output to be discharge at logical 1 (5V) but here i got the opposite)
Is there something that could be done?
Ltspice model is attached.
Thanks.
https://eu.mouser.com/datasheet/2/609/1261lfa-3124642.pdf
