RC Delay Circuit.
sgr
Joined Jun 27, 2017
34
What is the value of R and C if we want 2 mSec Dealy from 4.2V Input. IC will get enable if Voltage is more than 1.5V.
35,209
What is the amount of current you want delivered to the load?
What is the voltage at the load at steady state?
Knowing these two you can establish the maximum value of R.
Then you use the formula for RC charging circuit to determine C.
eetech00
Joined Jun 8, 2013
4,730
HI
You can use this formula:
T=-ln((V-Vc/V))*R*C
V is input voltage
Vc is voltage at Time T
So for V=4.2 and Vc = 1.5, I believe it works out to R=47K, C=0.1uF, T=2ms delay
eT
ebeowulf17
Joined Aug 12, 2014
3,307
HI
T=-ln((V-Vc/V))*R*C
V is input voltage
eT
I came to almost the same conclusion. Solving for RC, I got:
RC= -t/Ln(1-Vc/Vs)
RC = 0.00452
I think in your formula you need parentheses around "V-Vc" so that it's (V-Vc)/V instead of (V-Vc/V)
eetech00
Joined Jun 8, 2013
4,730
RC= -t/Ln(1-Vc/Vs)
RC = 0.00452
Yes...needs the parens. Should be:
T=-ln((V-Vc)/V)*R*C
Still resolves to 2ms, but if use your formula, I get 4.7ms.
When I simulate to check, Vc is about 1.45v at 2ms with 4.2v supply
