RAMPS 1.4 convert 12V on D9 to 6-8.4V
canteen334
Joined May 12, 2016
3
Hello, I ordered this laser and a RAMPS 1.4 outputs 12V on D9. The laser says it can input 6-8.4V so I need to step down the voltage on the RAMPS 1.4. I am completely new to this so I don't know what to get. I was thinking on getting either this or this. Please leave your opinion on whether this would work or not. Thank you.
dl324
Joined Mar 30, 2015
18,490
Welcome to AAC!
If you just bought the power supply, is returning it an option? You'd be better off getting one closer to your requirements. If you want to keep the supply, the first option you mentioned would be more efficient.
mcgyvr
Joined Oct 15, 2009
5,394
either one should work just fine..
You could just make your own with a LM317, a few resistors and capacitors too..
canteen334
Joined May 12, 2016
3
Welcome to AAC!
Welcome to AAC!
I'm currently using an atx power supply that someone gave me and I'm trying to keep the build within a budget. Thank you for your response.
GopherT
Joined Nov 23, 2012
8,009
What does one do with a 1.5W green laser?
