Rail - to - rail opamp
biteriu
Joined May 19, 2020
12
Ok... so I have this, a differential input. But it's not actually what I was hoping to obtain, what should I change to get a proper output (I mean by that a rail to rail output).... the gain?
I'll try a new schematic with real current sources and I'll work a bit on that intermediate stage.
ericgibbs
Joined Jan 29, 2010
21,651
hi b,
One pointer to the design error is that Vout swings above zero volts when driven by a symmetrical input signal, check the internal biassing.
E
Tako
Joined Oct 21, 2014
65
Try easier comparator architecture.
What is C3 and C4 for? I would delete them and add two more inverters at the output.
biteriu
Joined May 19, 2020
12
Well... I thought I should use them to get rid of the DC level.
I will try to use two inverters, but what are they for exactly, to have a better gain and the same phase?
Tako
Joined Oct 21, 2014
65
But what for?
What I understand, your aim is to create comparator with rail-to-rail input and rail-to-rail output. Is that correct?
If I remember correctly, you wrote somewhere that you are not satisfied with output value that should always be lowest or highest. More inverters in series should make output to be always on any rail. Phase depends on you, if you do not care you may have even number of inverters. More inverters, as you wrote, means more "gain".
