R2R ladder with OPAMP and controller
Nidhi123
Joined Jul 24, 2018
13
Please find herewith attached an Image of a block diagram.
In this now we are facing that we get output voltage which is range from -2.8 to -0.6 V for (111 to 001 combinations).
But in our application, we want -5V as output. so is there any option to get -5V as output? The controller which we are using is operated on 3.3V. so can we do this by using OPAMP as a differential?
Please guide.
38,869
Increasing the value of the 20kΩ op amp feedback resistor will increase the output voltage..
You can't get a negative output without a negative voltage, so you will need a negative supply for the op amp of a least -5V.
Ian0
Joined Aug 7, 2020
13,296
Something not quite right about that R-2R ladder - bit 0 seems to have no other connection than a resistor to ground.
