Question regarding the input resistors of a summing amplifier or op-amp in general...
circuitPhillip
Joined Jan 2, 2021
5
Greetings!
I have a question regarding the summing amplifier/op-amp. Looking at the schematic below, by using the formula for summing amplifier, theoretically we will get a Vo = -7V.
However, running the simulation, the results for the output voltage is 3.88V.
Of course, this changes when setting the resistance of the resistors, R1,R2 and R3 into smaller value like 10k.
My question is why does it behave like that? My only clue is that real op-amp (741) have an input resistance of 2MOhms on its own.
38,913
That's certainly a significant factor that can't be ignored.
Also look at the input bias current for the op amp (which is relatively large for a 741).
That will cause an offset voltage at the input due to the voltage drop through the very large input and feedback resistances.
Such high resistances can only possibly be used with an op amp with negligible input bias current such as a CMOS or JFET type.
ericgibbs
Joined Jan 29, 2010
21,627
hi phil,
Welcome to AAC,
Those 150M ohm are unrealistic for the very old 741, in fact for most general purposes OPA's
Who designed the circuit.?
E
circuitPhillip
Joined Jan 2, 2021
5
hi phil,
Welcome to AAC,
E
Thank you for the warm welcome!
The design is used to demonstrate some limitations of practical op-amp. I am uncertain which reason causes the output voltage to not follow the equation. So far, my only clue is the that it is higher than the internal resistance of the op-amp.
Audioguru again
Joined Oct 21, 2019
6,826
You are using a 52 years old 741 opamp, the "typical" values in its datasheet and an old Multisim simulator that does not even use "typical" values.
There are many 741 opamps with a minimum input resistance of 300K and maximum input bias current of 0.5uA.
