Question Regarding The CD40174 Hex-D Flip-Flop
sarahMCML
Joined May 11, 2019
703
Hi:
The positive-going clock pulse transfers the info on the data pins to the "Q" pins. Must a
clear operation be performed with a negative-going pulse or can another positive-going
pulse be used to update the output with doing a clear?
You don't need to clear any previous data to store new data into the registers, it's only there to initialise the registers if needed!
Note: I'm just putting up my Version 2 of the CD4511 leading zero blanking circuit, if you're still interested!
