question regarding tactile button connection
skemaayam
Joined Dec 1, 2013
how can i create a circuit consist of LED and tactile button to make the led turn on when press then quickly off. to turn on the the led on again, the tactile button need to be release then push again to turn the led on. same function as a controller game pad. thank you for your help.
Reloadron
Joined Jan 15, 2015
7,948
My guess based on your description would be a Non-Retriggerable One Shot Multivibrator which could be done several ways but using a 555 timer is likely the most popular. Another option would be a uC (micro-controller) circuit which is programmed accordingly. Also, "quickly" is not a very good description for a unit of time. Here is an example using a 555 timer chip.
Ron
