Those are just some MOSFET models in the simulator.Where would I get the mosfets in that simulation?
Their on-resistance is rated for Vgs=5V, so it would be better to find one rated Vgs-3V (if that's your Arduino output voltage).Would the RFP30N06LE mosfet work?
Yes, that should work fine.would the IRF9540 mosfet work?
It depends upon the application.how do you figure out what type of transistor to use?
Those are rather arbitrary.Thanks one last question how do you figure out what resistors to use in the h bridge?
It might, but why are you concerned about saving a few resistors?Would no resistor work?
