- Joined Jan 23, 2018
- 27,992
What do the instructions for that sand filtering thing say about a motor to drive it?
No gearbox. Have a look at about 2:40 here:That is just the motor, what about the G.B.?
Usually the agitate is often done in the fashion in my link, mechanical.
Max..
So it's determined by date rather than country?There is a few different methods, dependent on make model, the older ones did it with a G.B.
Max.
Likewise.I have never worked on them by profession, so only personal experience.
Max.
Our 1958 Bendix Duo-Matic washer-dryer had a tree speed transmission that provided two reduction ratios and a 2x overdrive. But probably that model is quite rare today.. And certainly I have not seen much of a gearbox on others, except for one brand that had a unique thing that delivered either a 10:1 stepdown or a straight thru drive between two pulleys mounted right along side each other. It was great for a minibike because it could power shift with no clutching.All the W.M. I've had my head inside don't have a gearbox just a belt round the motor shaft and a large pulley on the drum spindle.
