question about capacitors
Ghina Bayyat
Joined Mar 11, 2018
148
hi
i need to ask why are there two equations for calculating the capacitance of the capacitors ? in some books c = 10 / 2π f Xc and in other books it is c = 1 / rπ f Xc
which one is right ?
dl324
Joined Mar 30, 2015
18,326
hi
Neither.
\( \small X_C = \frac{1}{\omega C} = \frac{1}{2\pi fC}\)
WBahn
Joined Mar 31, 2012
32,827
so C = 1 / 2π f Xc is the right one
What you mean is correct, what you wrote is not.
It is pretty universal that multiplication and division have the same precedence and are performed left-to-right, so what you wrote is actually
C = (1 / 2)·π f Xc = (π f Xc)/2
What you should have written is
C = 1 / (2π f Xc)
Sloppiness in things like this WILL get you in trouble sooner or later. Either because you will tend to do the same sloppy things when you put the formula into a spreadsheet or a program, or because you will cause miscommunication with whoever later reads it (which might even be you).
WBahn
Joined Mar 31, 2012
32,827
hi
What is 'r' in the second one?
Which books give each of those? What is the context? Not that I can imagine any context in which either is correct.
