pyronics KX 15 ED, SENSOR CONNECTION
28,151
It should be possible to drive the base of a transistor with that signal, probably with a series resistor to limit the base current. But since we have not much more information, such as the common of the source of that voltage it is not simple to describe the rest of the connections. But the short answer is "YES", adding a transistor
